Mercruiser 3.0 head gasket
brian3127
Serial number of engine 4920382
The engine block was taken to a machine shop and bored .030 over. Do I need a special gasket for that?
And if I do can you give me the part number.
Thanks
Ayuh,..... Have you placed the gasket on the block,..??
Does the fire-ring sit on the block, just outside the bore,..??
Generally speakin', the stock gasket oughta work with a .030 over-bore,.....
Ayuh,..... Ya can't go wrong with Fel-pro gaskets,.....
