Mercruiser 3.0 L Alpha One Gen 2 Tilt & Trim
Drock1979
Hey Folks,
Ok so my tank on my tilt and trim pump is leaking bad. The replacement has arrived and believe it's just one screw to install. I have attached a pic of my pump but looking for proper tank replacement instructions. Don't wanna crack the new one or install it wrong. From what I gather there is 2-3 bolts at the back of the pump holding it onto the bracket and then just a single screw on the bottom of the tank up into the pump. Should I use 2-4-C grease on the O-Ring? Any help would be great. Love everyone here have been amazing thanks everyone.
Drock1979
Hey Folks,
Ok so my tank on my tilt and trim pump is leaking bad. The replacement has arrived and believe it's just one screw to install. I have attached a pic of my pump but looking for proper tank replacement instructions. Don't wanna crack the new one or install it wrong. From what I gather there is 2-3 bolts at the back of the pump holding it onto the bracket and then just a single screw on the bottom of the tank up into the pump. Should I use 2-4-C grease on the O-Ring? I will attach the pic of the new pump as well. It comes with O-Ring, screw, spacer & gasket. What order do these go in? Any help would be great. Love everyone here have been amazing thanks everyone.
from what I gather there is 2-3 bolts at the back of the pump holding it onto the bracket and then just a single screw on the bottom of the tank up into the pump.
Ayuh,.... That's the whole thing,......
