Pcholmondeley
Thread starter- Joined
- Jun 15, 2012
- 10
Have a problem with idling after full power run looking for comments
Boat starts and idles well but after running at mid or high throttle for any any length of time {and by the way is runs very smooth at speed** return to neutral it runs rough and misses on #2 cylinder proven by removing lead. The plug is sparking well. Once engine is shut off for a few minutes it starts up smooth again running on all cylinders and will idle all day that way until it runs under power again.
What has been done -
New manifold
Rebuilt cylinder head
Valves adjusted but oddly can not run if set to factory procedure will only run with 1/8 nut turn after zero lash
New plugs
New distributor and rotor
timing, compression test and tune up done by certified merc mechanic
He has ruled out ignition and fuel issues I agree as all cylinders share fuel input
Spark plug color is fine on all cylinders even after misfiring
His conclusion is the #2 valves must be sticking when hot or slight water leak into cylinder !
I am not sure I agree as it runs so well under power.
Looking for any thoughts or suggestions before I dismantle
Thanks
Peter
New manifold
New plugs
Thanks
Peter
