Mercruiser 3.0 Manifold Question
eric416
I have a 91 (i think) Mercruiser 3.0 which needs a new manifold and elbow. I need help identifing the engine year and manifold part number. I can only find the engine year by serial number to the late 80's. Here is the serial number on the block if someone can help.
Uploaded with ImageShack.us
Also, is this the right part number for the manifold?
Re: Mercruiser 3.0 Manifold Question
Ayuh,... If the motor is original, with it's original parts, ordering by using the serial # in the 1st picture, will get you the Right parts...
The numbers in the 2nd picture are merely casting, 'n manufacturing numbers, Not part #s...
eric416
the motor was replaced and the parts from my old motor were put on it which was a 1985. I couldn't find any other markings on the manifold for the part number
eric416
Update
Update
Ok so i did some more research and it turns out the motor is an 87-89. I was confused because i was told it was a 91. Now my question is how do i tell if its the 2.5L or 3.0L?
Re: Update
Re: Update
Ayuh,... By the Serial #s...
I believe the 2.5l was Long Gone by then anyways...
Don S
Re: Update
Re: Update
The SN on the tag in your picture is for a 1989 3.0L Model # 430B0009S
