Mercruiser 3.0 will only run at high RPM's
Will not idle and dies out.
Here is what I did:
Tried to start it last week, would not start. Narrowed it down to bad gas, I think. Drained out all gas in tank.
Replaced plugs, cap, rotor, fuel filter, changed oil and oil filter.
Put new gas in Boat, now it starts but will not run at low RPM's and will eventually die after a while at running at high RPM's
When it starts to die, I have to pump the throttle to get it to stay running.
Any suggestions on what could be causing this?
Here is what I did:
