Mercruiser 3.0 Please Help!
klos
I picked up a 18' bowrider for a fishing boat prodject. The block and head is cracked and I cannot find a used complete assembly or even a rebuildable core. The engine is a mercruiser 3.0, the boat is a 1989 Chaparral.<br />Looking in Michigan. Any help is very much apprectated.
Don S
Re: Mercruiser 3.0 Please Help!
Before you go looking for an engine, what condition is the drive in? How about the manifolds and risers? How about the transom (Dry Rot????) What else doesn't work.
cobra 3.0
DonS makes a good point. Negligeance may not only be engine related. You might be venturing into a real money pit. <br /><br /><br />Good Luck! Let us know if you find what you're looking for.
Once you've evaluated the rest of the boat like Don says,+ If you still are looking for an engine,...........<br /><br />I've got this Running take-out motor sitting in my garage.......<br />It's a Complete,.. Plug & Play engine,.....<br />
<br />The compression #s are posted on the valve cover....<br /><br />Here's a shot of the other side,......<br />
<br /><br />Post an email address,+ I'll contact you...
klos
The transom and stringers seem to be in great shape. Drilled some test holes and found good wood.<br />Bondo, I'm interested in your engine. Please let me know what year it is and how much $.<br />THANKS.
Go ahead,+ edit out your addy,........<br /><br />You've Got Mail.................... ;)
