Mercruiser 3.0 rough idle at start and stumbles momentarily during acceleration
fourtwenty
I have a 2001 Bayliner 175 with Mercruiser 3.0L engine. Does not have TKS. Bought it last fall, have had it on the water since late May. It drives well enough that I feel comfortable using it for cruising around the lake, towing tubes and water skiers etc. It will cruise all day at 35+ MPH without issue.
#1
When I start it from cold I have to give it throttle to get it going. It won't stay running if it's below ~1200RPM. After a minute it's fine and idles around 700RPM. Probably a choke thing?
#2
When accelerating, I give it throttle and it winds up to ~2200RPM. Then it starts to stumble, drops down to ~1600RPM then seems to clear itself out and then the RPM climbs to around 2800RPM. I then start increasing the throttle again. As soon as it starts to stumble I stop increasing the throttle. I don't reduce it, just leave it until it goes back up. In the attached video you can see I throttle up to around 2200RPM. It bogs down then winds up to ~2600RPM. I then give it more throttle without any issue. Flooding or starving?
Things I have done:
fiddled with idle screw and mixture screw per what I have read on these forums to get it idling nicely at 650-700 RPM at in gear idle, while on the water. I used a proper tach for this, not the one on the dash.
Check the accelerator pump performance (while motor is off). I can see a steady squirt of gas which is what I read there should be.
Any ideas what to look at next? Think these 2 things could be related?
  • 20210723_125908.mp4
Most likely it needs the carb rebuilt, but there is also a issue with the electrical system. Watch the fuel gauge it pegs full then drops to empty and then back up. Might be a bad ground
Clean both ends of all battery cables including the grounds (both ends)
fourtwenty
Thanks, I figured it might just need a new carb. Any suggestions on where to get a rebuilt one for a reasonable price? I rebuilt a carb once many years ago and the vehicle wouldn't run when it was raining so I don't think I want to try that again lol.
I'm chalking the fuel gauge thing up to a bad sending unit. Once the tank is about half-empty it doesn't register anything. I was going to look into that but it's lower on my priority list. I will check and clean the battery cables but they were fine when I checked them last fall when I got the boat.
Haven't bought a carb in many years, I would just search for "Mercruiser TKS" or search by part number 8M0084193 to see what shows up
fourtwenty
It's not a TKS. Found 807504N on the carb, presumably I can use that to find something.
CaptnKingfisher
I just replaced a Rochester carb on my omc 2.3 l. There weren't a lot of companies carrying that carb so I took a risk and ordered from flying fish carburetors (even though I read a couple negative reviews on this forum). But my experience was great, the carb arrived a week later and seems to be rebuilt perfectly. They also have a policy where they'll give you a paid for return shipping label and you can send em your old carburetor and get $68 refunded to you. They'll rebuild that carb for the next guy. I definitely would recommend those guys based on my experience
Kubaat3lover
Same issue with my V6 4.3L MerCarb when cold,
Im after carb rebuilt, boat runs great when cold, hot etc..
idle + mixture adjusted according to spec but..
it happens only when cold, 1st start of the day, it started immediately but when i do not keep 1000-1500rpms but put it on idle, RPMs are quite low and the blackish smoke is coming from the water, after a while its fine. the RPMS are higher, I can shut it off and start immidately.
On hot warm days there is no issue, only now when the temp was around 73*F
I will follow this thread
Take care
fourtwenty
I'm not finding much in the way of the mercarb for sale for a reasonable price but I have come across a few places claiming a rochester carb as a direct replacement, also with claims it's better than the mercarb. Anyone have thoughts on that?
