I have a 20 ft sea pro Duel Console with a Mercruiser 3.0 the engine has been given me problems idling so I bought a new carburetor that did not fix the problem then I noticed oil around the top of engine from blow by so I did a leak down test and I'm losing 40 psi give are take on every cylinder and its going to the crankcase ( that would explain the blow by) also notice that the oil was milky so I changed it and ran it down the river 1 hour total and the oil was milky again so now I know an overhaul / engine is needed... Meanwhile I have a Remained OMC 4.3 with lower everything still on another boat that I was going to replace the floor in but haven't got around to it ... should I use the omc equipment I have or rebuild / replace the Mercruiser engine ?
