so the 05 suntracker with 3.0L MerCruiser I/O i'm getting (included with another purchase) has a buzzer alert. the current owner started the boat today and the buzzer was going off. the dash lists engine overheat, low oil pressure and low gear oil as the 3 things it will buzz for. the current owner stated it buzzed last time it started and it lasted for about 15minutes and then it stopped. sounds like they ran it anyway. i know, not real smart. so the engine temp is fine and the oil pressure looks ok by the gauges. the gear oil reservoir looks low, so we grab some mercruiser branded gear oil he had stashed on the boat and put some in the tank almost up to the fill line. we let it run for a while and the buzzer never silenced. i had hoped that once the reservoir got some lube it would kill the buzzer. we never put the boat in gear. do you have to have the boat in gear to move the gears/prop to circulate the oil? if the reservoir is full can i safely (and slowly) take the boat to the marina (~5 miles away) to have it looked at.
my plan is to take it in and have them do whatever service needs to be done. this boat hasn't had a "service" in 1.5 years so i figure it's time. the only catch is that i need to get it to someone who can fix it. any thoughts. thanks.
