mercruiser 3.0L HP ratings
Status
Not open for further replies.
Levithan
Banned
I see 3.0L mercruiser power rating ranging from 120-140hp depending on the year, What makes the 20hp difference?
Is it just electronic ignition over points, camshaft differences throughout the years or a combination of both?
I currently own an 88 3.0L 130HP Merc and will soon be converting over to pertronics electronic ignition and coil.
I am doing it for reliability more over hp but if i widen up the gaps on the plugs due to the increased spark voltage will i gain anything?
Also my timing says 6deg btdc, if i run premium can i increase engine timing to say 12 and gain a bit of hp/torque like you would in a car or is that even advisable?
I like the power my boat currently has and am not looking for a bigger engine, but the above ideas are basically free and for reliability so if i can gain a little why not.
Anyone have a 3.0L hp chart over the yrs??
Howard Sterndrive
Re: mercruiser 3.0L HP ratings
there's no difference, really
the engine has just been marketed, and rated by different means over the decades (propshaft HP vs. flywheel HP for example)
there have been head and piston changes, and such, but 3 to 5 hp is probably closer to the real difference of those changes
it was rated 150HP with MPI injection (Volvo Penta application), that was probably a "real" increase
fishrdan
Head, manifold, higher compression.
Mercruiser never made a 140HP "3.0L". The 140HP 4cyl engine was the older 181CI version of the engine with HP rated at the crank, instead of HP rated at the prop like the 3.0L engines. 181CI and 3.0L engines are very close, but everything is not interchangable between the 2.
I doubt you'll see any performance increase with the electronic ignition. I wouldn't bump the timing...
the 181 ci and the 3.0 are the SAME. GM only made the 2.5 (151) and 3.0 (181) 4-bangers.
PB48052
I just bought a 18' Searay bowrider with a swapped 1988 3.0 Mercruiser, old style distributor. The engine sticker says 42-4600 W.O.T., 6° BTDC, and 130hp. Other model years I've looked up give it 44-4800 max W.O.T., and different timing specs. Trying to finalize a prop lately, boat currently runs solid 40 mph (GPS on phone) and 4420 RPM (calibrated inductive shop tach). Just wondering why the specs vary from year to year. Would really like to know the peak torque RPM. I always propped my outboards at or near redline with light load, and never blew one up, but really don't want to spin this 4 stroke that fast if it's a concern. And would like to know if I'm already getting peak torque at 4420.
inlinners are 4200-4600 RPM
your 4420 RPM is good
torque peak is about 3800 RPM with stock cam
specs vary year to year depending on which induction system and which ignition system
GA_Boater
This thread died almost 9 years ago.
Closed.
Status
