Mercruiser 3.0LX Flooding Problem - New fuel pump pressure too high
Status
Not open for further replies.
flash3610
Fellow do-it-yourselfers,
I am posting this because I wish I could have found a post like this instead of struggling along and spending more time and money. This post is intended for folks that have recently installed a new mechanical fuel pump and now find themselves fighting a flooding problem. I think the remedy only applies to a specific set of Mercury engine model(s) but I can only attest to the fact that my 1997 Mercury 3.0LX A1 s/n OK018438 has this peculiarity.
The symptom is an engine that will not idle and will die coughing up fuel through the carb throat and then proceeding to drip fuel into the intake for a few minutes. The typical advice I found on multiple boating forums is to rebuild the carb (in my case a Mercarb 2BBL) and or to replace the float needle with the new spring version. That exercise was very informative and not difficult to do by following the instructions. However, that did not solve the problem.
What solved my problem was to replace a resin-based "shim" between the recently installed fuel pump and the engine in addition to the normal gasket. This shim was not mentioned or included in the manual or parts drawings that I was able to find. It was, however, installed at the factory and unwittingly left out by me when I replaced the pump at the end of last boating season. Thank god I saved it because the Mercury mechanics I talked with had no clue what I was talking about when I called them to ask about what it was and if it were required.
Apparently the lever that is inserted into the crank housing protrudes too far into it and the lobe that contacts the lever to operate the pump displaces it to far causing the pump to output the fuel at a pressure to high for the carb overcoming the float needle which then remains open even when the bowl is filled to its maximum capacity. This dumps fuel into the carb throat. The shim reduces the amount that the pump level extends into the engine and reducing the lever action and output fuel pressure to an acceptable psi level.
Another thing worth mention is that the gasket pattern for the fuel pump and the shim are not the same. The shim seems to match up well with the engine but not the pump or pump gasket. The bolt holes line up fine and this mismatch is apparently normal. Make sure you use a gasket sealant.
Happy boating season from Woodinville!!
Chris1956
Re: Mercruiser 3.0LX Flooding Problem - New fuel pump pressure too high
Flash, You might repost in I/O section. This is for merc OBs.
flash3610
Will do... Rookie mistake :redface:
helmetron
I have a 1997 Bayliner Capri. It has this flooding issue. I had the carb rebuilt and the same thing happens. Can you provide me with a picture of the shim so I can check mine. I do not know if the previous owner replaced the fuel pump and left this part off. Can I just put an inline fuel regulator to resolve the issue ? What fuel pump would be a good replacement?
Thanks in advance
generator12
Thanks in advance
Helmetron, I'm not the O.P., but I had the same issue. Make a spacer out of gasket material about 1/8 inch thick (trace the fuel pump gasket onto the material and cut to it), even if you have to double up some material to do it. This will reduce the pressure. If not enough, add more until you get down to the pressure you need. But before you begin, be sure that you know what pressure you're looking for.
I have a '86 Merc. 470 and brought mine down to about 6 PSI. This made it work just fine. Prior to that, it was over fifteen and flooding the carb.
rfb
Thanks so much for posting this.
I have been going round and round trying to figure out this problem after putting a new fuel pump on my 3.0 Mercruiser.
I would have never guessed the solution, and it works.
The Shim is gasket 431861, which I suspect was not on the original fuel pump because it was a different part that did not need it.
bobsemp
Thank you! I've been tearing my hair out and darn near blew up my (new to me project) boat with the flooding caused by a new fuel pump w/o the spacer. Now I know what the issue is! Would have been nice if this was more widely known and/or actually shown in the Mercruiser manua.
Status
