Mercruiser 3.7 170hp overheating problem
southwest395
I have a Mercruiser 3.7l 170hp 4-cyl, with an overheating problem. I have changed the impeller, the raw water hose from the outdrive and inside on the block, the heat exchanger was not getting raw water, but I pulled the hose off of the copper inlet and raw water was coming through, so that tells me that the impeller is working, however the boat motor is still overheating between 170 and 200. You can smell antifreeze through the exhaust, and it is spilling out through the overflow, is there a water pump or thermostat on these motors? The inlet hose from the heat exchanger is HOT and not just warm to the touch as I understand that it should be. I recently had two tubes plugged in the heat exchanger, there is a pinhole in one and water and anti-freeze is spraying from it, would this cause the overheating problem? Is there any way, that when you are changing the coolant and raw water hoses, that you can bleed the system?
southwest395
Re: Mercruiser 3.7 170hp overheating problem
And if i correct this has a alluminum block or head. At what temp does it worp the head or block. To where you will never get it stop leaking coolant again. Just wondering cause i hear it happeneds.
southwest395
Please is there any 470 owners that can help
KCKracker
if you smell antifreeze then you have a leak unless its spitting out the overflow?
check the following:
pressure test the closes system, is it leaking down? if so, where. could be the exhaust manifold into the motor, any of the exh gaskets, heat exchanger, really anywhere on the engine,
also is there a drip near the front under the pulley? if so its the pump leaking.
at any rate, anytime you have a LEAK you lower your boiling point and will overheat,
I have a 470 and id start with heat exchanger and leaks. PRESSURE TEST THAT!
southwest395
I had the heat exchanger serviced and repaired before. Cause coolant was leaking out the outdrive. one of the tubes that where has a pin hole leak now. Would that cause it to over heat and blow coolant out the over flow bottle. no drip under the pully and no leak under the pully
stonyloam
Time for a compression check and a cooling system pressure check. Go to Autozone and borrow the tools. Sounds like it might be a head gasket problem. Not a bad job, just have to be careful to follow the manual exactly if it is a HG.
KCKracker
if it is leaking anywhere it will lower the boiling point, especially a bad cap.
my concern is your smelling it out the exhaust,
how long does it take it to overheat at idle?
is the oil still clean?
have you pulled plugs to see if any cylinders are wet?
have you done a compression test?
southwest395
oil is clean, spark plugs are not wet
KCKracker
if you want help you need to take the time to answer questions in completion, or nobody will take the time to ask them ;)
southwest395
I checked the spark plugs and check oil. Oil is not milky and it doesnt look like a milk shake. Oil looks new just as like i did a oil change. I took pictures of what the spark plug looks like and it smell like fuel no coolant and took a picture what the heat exchanger and took a picture of the front of the pump and pulled all the hoses no crack or signs of oil and coolant mixingIMAG0286.jpgIMAG0287.jpgIMAG0288.jpgIMAG0289.jpgIMAG0290.jpg.
southwest395
About 30 mins at idle before it gets to 185 degrees. About 20min at full open throttle.
KCKracker
BLAM we got goooood input now! ok thats a long time. a headgasket would be fast. that sounds like lack of water flow and its slowly unable to keep it cool.
if it were me id pull the Tstat and check it on the kitchen stove, then exhaust manifold off and have it checked for cracks, leaking gasket, but mostly for being plugged up with crap, really sounds like a small leak or lack of flow on the manifold. get that sucker pressure tested off the engine!
southwest395
Please give me a location of where the thermostat is on the motor. I thought it would be on the front where the pump is under the three bolts and the hoseing is. but i didnt see it there.
southwest395
The pin hole leak isnt helping either on the heat exchanger. So that as well not helping.
stonyloam
What year/serial number of engine?
southwest395
Serial number is B406239 the boat is a 1986 sea ray deville II. So i would asume the motor is a 85 or 86. If it was a bad head gasket wouldnt the coolant mix with the motor oil.
southwest395
southwest395
Ive pulled off every coolant hose on my motor. I didnt see any thermostat on there. Is there one suppose to be there on this motor or no? Does anyone have a location to look for it? Thanks
southwest395
Took thermostat out and put in a boiling pot of water it awhile to open up. And it didnt open up all the way only about 1/4 of a inch. Then took it out of the water still has not closed at all. Would this be a problem with the over heating and it blowing fluid out of the over flow bottle
