FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Started up all day long on Thursday, now won't fire. Electronic ignition, put on new coil, checked plug wires, plugs, distributor cap and rotor.....still no fire. Any suggestions?
Kill switch have the lanyard installed? Do you have power to the + terminal of the coil with the key in the run position? Could be a coil, have you checked the coil with an ohm meter? It may also be the electronic conversion. No way of testing those things.
Well, you better go do it. You won't know what to fix until you do.
Meter on VDC, black lead on good clean unpainted ground, red lead on the + terminal of the coil. Crank the engine over and see what the voltage is while cranking.
