ImperialV184
Thread starter- Joined
- Aug 4, 2011
- 99
Hello, need some help here. Just fishished complete rebuild of my mercruiser 165. I was doing a quick dry run of the engine, no fuel, but using the starter to turn over the engine to verify oil pressure. When I turn the ignition just a bit, it turns then stops. When I give it about 5 seconds and turn off ignition the starter continues to run for a bit. It ieventually stops after about 20 seconds then stops. Seams like relay is sticking but verified hot wire from ignition goes cold when key is off. Something is keeping the relay open and providing power. Checked all working, and two relays. Everything is new, starter, starter relay, ignition switch, coil etc. I did install the after market alternator conversion kit and removed stator and voltage regulator, Everything is new, put the old relay in an got the same response. Have come too far in my own to take it into a shop. Planning on adding fuel and cranking this weekend. Thanks for the asistance.
