Old Yeller Boater
Thread starter- Joined
- May 17, 2010
- 191
Thought I'd start my own thread to document a few thing in the hopes of someone else being able to find it in a search in the future.
Now that I have my head gasket problem solved, I'm moving on to my carb issues. I'm having two problems. First, starts either warm or cold take a great deal of throttle and playing to get the motor to catch and run. Lots of cranking on the starter before it catches. The second problem is significant backfiring through the carb when I give it too much throttle.
I've got a new starter and will be installing it tonight. Someone else reminded me to have the battery checked, so I'll take it to the local auto parts store for load testing. That way I'll be sure that part of the system is a-ok.
I'm also going to check the timing tonight to be sure it's at 4 degrees BTDC. After that, I plan to take it to a carb guy for a rebuild and proper setup. I know this could be overkill and not my problem, but as this boat is new to me, for a relatively small amount of money I'll have some piece of mind and know for sure that it's good.
Next step will be to wrap insulation around the fuel line to help prevent vapor lock.
So, some work and testing are in the works. I'll report back my results along the way. If anyone has any thoughts/input, as always it's appreciated!!!!
