86Rinker19ft
- Joined
- Apr 16, 2011
- 38
Hello all, new to the Forums. Have a question, well a few questions
I have a 19ft. Rinker with a 3.7 Mercruiser, I recently swapped out the engine for one that I pulled out of a parts boat i purchased. When I bought the boat the previous owner was able to start it up and let it run for a while so i could see the engine was good. Now I need to mention that he had a HUGE battery charger/starter deal hooked up because he said the battery was almost dead. I thought nothing of this at the time but now I have some questions about that. SO I get the engine in and try to start it, it acts like the starter is bad or the battery is shot, so I made sure the battery was fully charged, cleaned ALL connection points, replaced the starter relay, added an extra ground cable, and tried again. Pretty much the same result, so at this point I decided the starter must be dead. About this time i also realized that this new engine didnt have the voltage regulator and whats worse is that the two wires that would go to it were just freely hanging!? Now remember, the engine did start and run fine when I purchased it pretty recently. So anyways, I start to remove the starter and notice that the nut AND starter stud are BOTH spinning. So the first question is, how will I get that starter off? Are the studs pressed or threaded? (I have a SICK feeling that I am gonna have to pull the engine, remove the flywheel cover and flywheel to access the back side of those studs and then go from there....PLEASE tell me I am wrong) And the next question is, does that voltage regulator have to be on there to start and run the engine? I have another regulator but it just seems funny that it ran before? Was that possibly due to the BIG car battery charger he had on it to start it? Also, I have the alternator conversion kit but there doesnt seem to be room to install it without relocating the main fuel fill hose?
ANYWAYS, thanks in advance for ANY advice, and please be ready for more questions
