90baylinerV8
Thread starter- Joined
- Aug 3, 2010
- 2
i have some good aftermarket fuel pumps fromn my old play truck. can i replace the pump in the boat with the auto fuel pump or is it a no no like the carb is.
the aftermarket pump i have is threaded like the oem. it does not have slip on nipples that use clamps. the only visual difference i see without pulling the one out of the boat is mine is polished aluminum and my fittings are not in the same locations. so i would have to run two new fuel lines.Unless you are talking about an electric fuel pump, than that is a super no-no. Can you imagine a line coming loose and dumping fuel non-stop into the bilge and then overboard?
the mechanical pump use a diaphran that the bottom of must be exposed to atmospheric pressure because it goes up (sucks air in) and down (pushes air out).Thats why there is a small hole in the base of the casing. Marine use requires this hole have a hose fitting to carry any fuel from a ruptured diaphram up to the card and dump it in there instead of in the bilge.
