Mercruiser 350 MAG MPI 5.7L + Smartcraft (LOST ENGINE COMM ERROR)
benchircop26
Hi, this season i took off the engine from the boat as I had to reseal the stern inside out. The engine is working fine but sometimes before starting I am having an error LOST ENGINE COMM. The engine looks fine and I tried to check harnesses/plugs but everything looks fine. Does anyone had the same issue or maybe you know some troubleshooting. Thanks in advance.
alldodge
No easy way, its probably a loose connection. Look closely at the pin contacts, and this isn't the main power cable, it would be the harness and junction box, and terminators
benchircop26
Will go tomorrow and try to check them. Also mechanic didn't find any errors on the engine itself so you are definitely right. Thanks a lot for your help.
