Mercruiser 350 mpi horizon 2007 max rpm 2500 today
Recoba20
My horizon 350 won't come up to plane today. No errors on temp etc. But comes up in Max 2500 rpm . Split the control the other day to see if the trim had lost any contact but probably the trim sensor at the drive) Could I have done something wrong with the wire so it can't run max when I put it back? Feels like I got it back like before but became unsure now. Anything else you can check? No growth under the boat or drive. (Sorry for google translate)
Scott06
Is t there a switch that sees f you are in gear vs neutral ? If so might be limiting rpm just thinking it’s not in gear
Motor serial number please?
and what do you mean by split
QBhoy
Hi. Mpi after the early years, have a neutral safety switch in the remotes. Doesn’t let you rev past 2500 in neutral. If you’ve disturbed that or it’s making a contact when it shouldn’t in there…this is the result perhaps.
But. The mention of a trim sensor there. Some models have the same limiting rpm when the drive is tilted beyond a certain height. All the best.
Recoba20
båten går att köra i 6 knop och temperaturen ligger bra. det är en knapp på reglaget och verksr fungera med back fram och neutral. kanske missförstår det dy syftar på?
Recoba20
I was looking inside if somthing looks wrong but couldn’t see some problem . Were can I find the motornumber?
the boat can be driven at 6 knots and the temperature is good. it's a button on the controller and seems to work with reverse forward and neutral. Maybe I'm misunderstanding what you're referring to?
ok Throttle only button
Motor number , look just above the starter for a plate
