Re: Mercruiser 350 Riser Overheating
Ya but how much water ....... saw your pic of water coming out of block ...if thats full pressure you don't have enough water hose pressure on muffs.
MAN THIS IS WEIRD ....
read thru this then try what follows ...
For example the circulating pump on a standard small V8 GM based engine will flow approximately 50 gpm through the engine. The typical raw water supply pump is capable of flowing about 18 - 20 gpm depending on the gear ratio and restriction the system experiences. A standard 300 Hp small V8 engine dissipates approximately 300,000 Btu/Hr of heat into the coolant. To maintain a thermostat temperature of 160 degree F at wide open throttle this engine would need a pump to flow about 8 gallons per minute (GPM) of 70 degree F water into the system to maintain this engine temperature. Since the Alpha raw water pump can flow 18-20 GPM there is significant bypass (excess) water supplied, which therefore has to be dis-charged somewhere.
In a cold manifold system the warm water that flows through the thermostat, as well as this excess bypass water are joined together in the thermostat before exiting and being introduced into the bottom of the exhaust manifold. The fact that your are mixing together a lesser amount of 160 degree F engine water (8 GPM) with 10+ GPM of cold lake water allows the aggregate coolant temperature in the manifold to fall below the 110 degree F threshold needed to prevent the accumulation of condensation in the exhaust system.
put the boat in the water and see what happens ..... I have thrown this link in just for reference RE RISER TEMPS ...
http://www.acms-usa.com/bulletin_files/hotItem.htm
MAYBE ITS YOUR MANIFOLDS THAT ARE THE BLOCKAGE PROBLEM ???
maybe your hose pressure is way too weak and the boat needs to be in the water .......
