homelite
- Joined
- Aug 13, 2002
- 160
I have a 1995 Bayliner 2252 cuddy with a Mercruiser 4.3LX. I purchased this boat new. At about 200 hrs. I started noticing a clicking noise when turning full left or right. Most noticable in gear (idle speed). Now at 440 hrs it is getting worse. I pulled the drive. It slid off and back on ok so I assume the engine alignment is ok. I don't see anything wrong with the "U" joint. I don't see how it can be the gimble bearing since it only does it turning sharp either way. It feels fine when turning it. I have a "lubed for life" "U" joint. Could it be noisey even though it is not worn (sloppy) or tight? One dealer told me Bayliner has a thin transom and the outdrive is turning farther left and right than other boat builders and it is normal?? Looking for advise! As an automotive technician I'd like to correct it but I hate to replace parts that appear good and still have the same problem.
