CRLawrence
- Joined
- Aug 2, 2020
- 6
Hey guys, I have learned a lot in a short amount of time on this page since I bought my first boat a month ago. The boat I purchased is a 2002 bayliner Capri 185 with a 4.3l merc/alpha one. The boat had a new long block put in it at the beginning on the summer and was ran once. I have put 21 hours on it while I have had it. I couldn’t be more happy with the boat until today. I hope you guys have some input. Here is the situation. Had the boat on the water at 11:00am, per usual it fired right up ran great, pulled some tubes around the lake, let the kids swim around, at 5:00 we decided to wrap up and head towards The docks. On our way in we decided to stop at the cliffs on our lake and let the kids play and jump off. I’d say we were WOT for about 3 minutes over to the cliffs. Dropped the kiddos off and I stayed on the boat and just cruises around at low idle in gear and out of gear to keep the boat away from the cliffs I would say 30 minutes in total. We then loaded the kids up, I killed to motor while the climbed the ladder, and fired it back up no problem and idled put away from the cliffs with no wake while the kids got settled. I then got into the throttle pretty deep and right before the boat came up on plane the motor died. This has never happened, I immediately push it back to nuetral and try to start it. It just turned over and over. So I’m freakin our and start tearing apart the seat to see if it was maybe a loose coil or if there was anything loose. Couldn’t see anything, checked all fuses. So now I think maybe it’s fuel related, maybe I lost the mechanical fuel pump. A nice couple came up to us after 10 min and offered to pull us in so I said absolutely thank you, we cruised to our ramp at 7-10mph, when we got to the dock I tried to fire it again and nothing.. I then went and got my pickup and trailer, fought it onto the trailer, pulled it out of the water and started unpacking and putting covers on and I just happen to think try it one more time, the darn thing fired right up. Do you guys have any opinions. Could the motor have been flooded from idling around at the cliffs for 30 min and then when I hammered down it couldn’t get enough air and choked it out? Only thing I did before this trip was change the water seperating fuel filter. Thank you in advance
