navigateur29
- Joined
- Jan 31, 2023
- 13
Hello,
sorry for my english mistake, I'm French and I don't like translators... ;-)
I bought a boat having a Mercruiser 4.3 2003 with 6 cylinders
price was low because there is no ignition and I was aware of that
I don't know exactly what did the previous owner supposed
to be a "nautic professionnal"...
I can't find the correct electrical scheme in any Mercury manuals
That's always for carburator engines and coil has wired connected
to screws but mine has a connector with 3 wires + of course the high voltage one
I made a test with a spark I put directly to the engine and there is nothing
I made another test with a direct power applied to the the coil
In the connector, the purple wire has the +12v from battery (that's fine)
I didn't find any voltage on the 2 other wires
I supposed that the wire in the connector at the oposite side of the purple one
was the ground driven by the calculator (to cut of primary of the coil)
I made a direct test and I know that it works because I received the high voltage in my fingers ;-)
so my conclusion is that there is no ground signal coming from this calcultator wire...
question1:
what is the purpose of the third wire in the middle of that connector?
question2;
what can inhibit the ignition on the calculator?
what should I check in such case?
question3:
does someone could provide the capture of the ignition wiring for this engine model?
the one showing the 3 wires connector of coil
any suggestion that may help me to go further are welcome
many thanks
question1:
question2;
question3:
many thanks
