Mercruiser 4.3 possible mis alignment
dontask
I'm new to this forum and I was hoping to get some input from one of members that has Mercruiser factory training and or professional experience. My question is I bought a boat with a 4.3 ? alpha 1 drive. After getting the boat home for further in depth preventative maintenance and needed repairs I found that the engines forward two mount (left side & right side) top nuts were 1 to 2 turns from being tight. My concern and question is do I need to pull the outdrive and check for alignment? Or is there some tolerances built in? FYI I'm a mechanic for a living (35 years) I just don't work on boats for my 40 hr week. I have owned outboards all my life, just never an IO. thank you
APPALOOSA2
Re: Mercruiser 4.3 possible mis alignment
First I would download the manual that Don has put in "ADULTS ONLY" for your Mercruiser. This way you get the specs on tightning those mounts to the correct specs.
Yes I would go to Ebay and about $60 you can get a alignment tool. There is not a big tolerance at all for alignment. The $60 will save you a lot of money down the road, plus you can grease the ujoints with the outdrive off.
Ayuh,... The front mounts should be Tight, 1 nut holding the motor up,+ the other nut cinching the mount to the lower nut...
Hopefully, the mount hasn't destroyed the threads in that area of the mount from vibration...
dontask
Up date: No the threads were not torn up. Has any other Mercruiser owners here seen this before? Meaning nuts backing off or was it just poor assembly from Mercury (approx 160 hours on boat).
Don S
It wasn't Mercs fault. The boat manufacturer installed the engine and adjusted the alignment, they may have not tightened them, but then the selling dealer usually gets the boat with the drive off and has to install them. So then the alignment should be checked and the nuts checked for tighntess. It's part of the predelivery insptection.
Also, the drive should be removed and the alignment checked every 100 hours or yearly, whichever comes first. If the alignment was off, they should have been checked then.
Never have understood this type question though. What's the difference if it has been seen or not, YOU have the problem not everybody else.
