Mercruiser 4.3 - possibly blown up?
NatedoggAZ
OK - so I found this number on the starboard side above the starter right next to the flywheel.
Looks either like:
10066011 (most likely)
OR
11099001
thumbnail
I also found this on top of the header:
thumbnail
NatedoggAZ
Would either of those numbers be my block casting number?
Thanks!
ND
NatedoggAZ
Guess I could have used the internet machine to look it up..... looks like 10066011 is a GM block and it's legit....
if the motor is original to your boat, you have a 1987-1991 motor
you can jump to a 1996 or later motor if you drop in a complete motor with accessories. (dont try to mix and match)
if you need to "build" a motor. use a 1988-1991 block, use 1996 or later heads, use a 1996 or later vortec 4-barrel intake
then you can use your accessories, damper, and flywheel. you will have the benefit of the vortec heads without the issues of changing accessories. however you wont have a balance shaft
