dlogvine
Thread starter- Joined
- May 4, 2015
- 839
I looked at the manual for installation of the oil pan with a new gasket. It says to use some RTV gasket silicon at the oil rear seal and the front timing cover at the joints. I wonder if this silicone should be put under the gasket or between the oil rear seal and the block and between the front timing cover and the block. Thank you.
