Malibu-m1700
Thread starter- Joined
- Jul 6, 2014
- 6
I'm having a issue with my 2000 4.3l mercruiser, it has 50 hours on the engine & 150 hours total on the boat. The engine block was replaced after it had froze. I bought the boat off a buddy he couldn't remember what was all replaced but it was a $5800 repair. The boat was used for 2 years after being repaired (with no issues). The boat was not being used & I purchased it. The unit ran good the first couple times out, it then lost a bit of power, I found the exhaust flappers had come apart, I replaced them & made a few more trips. I did notice after a long high speed/rpm run that the buzer would go off, if I pulled the throttle back about 1/8-1/4 throttle the buzzer went away. Oil pressure, rpm were good but the temp was a touch high & the starboard manifold (it has the 1piece manifolds) was hotter than the port one. While winterising I noticed water on all the starboard spark plugs, while running on the flush hose the water out the starboard exhaust was aerated. I checked compression (all good on both sides), I did a leak down test (5-8% on all cylinders) the only bit of leakage seemed to be coming out the crankcase breather. I removed the manifold & ran water through the cooling inlet, no water came out the the exhaust port side of the manifold only out the bull horn side. Any tips or advice would be great. I was thinking head gasket, or possibly cracked head but I think that should of showed up in the leak test?
