Mercruiser 4.3 will not start after using diesel to free stuck motor.
nic420
Got a Bayliner 2552 w/ a Mercruiser 4.3 V6. It had been sitting for 25 yrs and the motor was frozen/seized. I poured diesel to free up the motor. The motor was freed up but will not start. It does turn over. I sprayed ether and it helped but will not combust. Got new battery, starter and new plugs. I was wondering if I should pour high octane booster into the spark plus holes to help start the motor?
nic420
1992. Have not checked color of sparks yet per new spark plugs?
Scott06
verify you have spark
Do you have compression? If valves are hung open You won’t have any compression and you may not pull Enough vacuum to get anything in the cylinders
Being a 1992 you should have a TB4 ignition. Use this to see if everything is working
TB5 is same as TB4
what is the compression?
if you dont have a minimum of 130 psi in all cylinders, you really need to pull the motor apart to fix. 99.99% of the time, even if you get a frozen motor spinning, the rings are still stuck, the valve are stuck in the heads and the bearings have been eaten up by either rust or the acids in the oil
did you rebuild the fuel system? sitting for 25 years, everything from the tank to the carb will need to be mechanically scrubbed clean. did you pull the fuel sender and clean the tank? if not, do so. did you pull the fuel pickup tube and anti-siphon valve and clean them? if not, do so. did you pull the carb apart and chase every passage with a fine wire to make sure they are clean, then re-assemble per the manual to set the linkages and float correctly? if not, do so
you need compression, spark and fuel at the right times for combustion
QBhoy
I should think that it will have little chance of starting if the diz cap and rotor has sat all that time. That will be toast by now. Or at least need cleaned. Carb will be suspect too.
Lou C
I'm agreeing with Scott, just because it spins doesn't mean it can make compression.
nic420
I forgot to mentioned I also poured diesel down the carb also.
nic420
I already took out the old gas in the tank and was running the motor hooked up to an external gas tank w/ fresh gas.
