FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
well, you got two out of three - spark, fuel, compression - should run
are you sure you have spark??
if you do have spark coming from the coil tower, then by all means you should have spark going to the wires - pull the cap and check the rotor/cap - broken parts??
might be weak/intermittent spark too - possible ignition sensor problem - if its never been replaced, do it - it will eventually fail
got it to work guys thanks so much and i apologize for replying so late... The problem was inside the distribuitator... i took it apart and i found a broken rotor...(so relieved it was something that simple ) Now i have a different problem with water in the oil but i just created a new thread for that, hope you check it out...Thanks again folks!
I still cant find the choke on this boat, does it even have one on the boat? I kinda had issues turning it on when cold but i figured i had to give it some throttle to turn on faster... i guess ill create another thread once i fix the oil thing..hahaha.. alright guys, thanks...peace..
the plate that is above the two barrels that rotates open and closed is the choke plate
on a cold engine it should be open like in the picture - pump the throttle once and the plate will close all the way - one more pump of the throttle and crank the engine over - should start
once the engine is running the electric circuit will heat the bimetal coil in the choke assy (stbd side of carb - round and black) and the plate will slowly open as the engine warms up
