Dan F.
- Joined
- Feb 10, 2010
- 13
Hey yall. Well after another successful rebuild after my last rod knock thread I have recently developed an Idle issue with this 2000 model motor. Runs fine at idle then starts to break up till the ECM kicks up the idle momentarily then runs fine again till the break-up starts again. Even stalls on occassion. Was told there was a filter screen behind the IAC motor that may be carboned up but there ain't one in there. Replaced IAC motor since the motor runs great with a little idle bump but that had no change to the idle problem. Any ideas? Idles at about 700-750 rpms on the trailer so low idle concern isn't a problem. Not about to start shotgunning sensors at it without good reason. Figured with the wealth of knowledge here,someone may have a clue what to look for. Oh yea,no water in both filters either so that ain't it!
