Mercruiser 4.3L lift points
liusigou
I only find one handler for mercruiser 4.3L 185HP, Where are other handlers? I am going to do the coupler maintenance and need pull the engine out.
If your talking about lift points, sometimes they are removed after install
Can use a bolt and put it thru the chain and attach to the head.
I like using 2 one inch lifting straps and place them under the exhaust manifolds and attach to hook above carb
liusigou
Can following lift straps work or not? (This synthetic nylon sling boasts a capacity of 4,800 lb basket, 2,400 lb vertical and 1,920 choker for a variety of hoisting and lifting applications.
Yes, so long as they are opposite sides and ends
Exp: left front right rear
liusigou
It seems that the gimbal bearing installation tools touched the coupler during the installation of gimbal bearing, the alignment tools cannot be pushed into coupler and I pushed the tools very hard and the alignment tools was broken. So I doubted coupler was damaged by me while mounting the gimbal bearing.
But today I did a another testing and I can push yoke directly into coupler, Do that mean that the coupler is still ok.
Scott06
Yes if you can get the yoke in you should be ok. Your alignment tool may not be made correctly. I think there is a dimensioned drawing in the stickies
liusigou
It seems that I need not replace the coupler. The alignment tools worked before . You can see the obvious damaged edge in the second picture. I will buy another alignment bar
liusigou
It seems that I need not replace the coupler. The alignment bar worked before . You can see the obvious damaged edge in the second picture. I will buy another alignment bar
Scott06
No picture were attached. Why don't you file the high spots down on the bar vs buying a new one.
liusigou
The alignment bar can be pushed into couupler after I filed some high spot at the end of alignment bar. Thank you Scott06 so much
liusigou
Today I got a new alignment bar, But I cannot push it into my gimbal bearing even the diameter is 1.3820 inches. and The old alignment bar is 1.3740. So the old one can be pushed through the gimbal bearing.
Bt Doctur
you state you replaced the gimbal bearing, what did you use to install it?
Was the drive difficult to remove?
Gimbal bearing may not be centered, did you rap the slignment bar up,down,left,right?
liusigou
I am concerned that the old alignment bar was damaged and it will damage the coupler if I apply to do the alignment job. so I bought one. But the new alignment bar cannot go through the gimmbal bearing.
I am trying to do the alignment from gimbal bearing to engine.
My old alignment bar can be pushed through the gimbal bearing, but the new one can. I measured the diameter of new bar, it is 1.840 inches. But my old one is 1.374 inches as shown in two pictures.
04fxdwgi25
Dimensions
  • Engine alignment tool dimensions.pdf
liusigou
The water is warm and seems too slow to come out while running motor. Any solution?
  • PXL_20230815_192025711.mp4
liusigou
Water is very warm and it is slow. I did grab some iron rust off in the water pipeline
