I already replaced the impeller. I remembered yesterday that I accidentally ran the motor with the hose off for at least 45 secs. There were barely any splines left on the impeller. I replaced everything I could with the rebuild kit and fired her up with water on. I noticed there were two decent streams of water coming out both sides of bell housing area but not the center of prop. Is this normal? I never had cause to look before.
Also, she started to overheat. Either the thermostat is shot now or there is an obstruction. Temp climbed to 155 and she did not back down. It is possible there is some shards of rubber in the system but were do I start to look? How do I back flush?
Ayuh,.... Ya gotta find All the missin' pieces,....
By back-flushin' from the t-stat housin, with the lower unit Off, that'll clear the line from the impeller, to the t-stat housin',....
If ya got P/Steerin', the in-line Cooler is a likely candidate for collectin' the bits of the old impeller,..
It's 'tween the impeller, 'n t-stat, under the motor,...
With the key "On", yer temp gauge should show the temp of the sender, 'n go to Full Hot, when ya ground out the sender wire,....
The fact that yer seein' exhausted water from the idle relief ports, insteada the prop, tells me yer shutters got burnt up, 'n fell down into the y-pipe too,....
Flushed back from t stat inlet hose. The stream from the outdrive copper pipe matched the garden hose. So that is clear/clean.
I did turn key to on position and the gauge did reset. I will need to test that. Assuming the shutters are burnt and fell, would that clog create overheating do to hot water not escaping fast enough? Also, still need to understand where to find those shutters.
Okay I found the location of the dual exhaust elbows. I used Boatinfo - The library, containing manuals, brochures and other technical documents from the last hundred years! . Great resource. How do I get these bad boys off? They are free but so rigid I can slide them enough. Do I have to remove the elbow from the manifold first? If I do will I need a new gasket?
Update...Port side shutter is intact but starboard shutter is gone. How do I get that out of there? reach down? remove bell housing? what is the easiest way?
Is it possible to have a blown head gasket? How would I check? The manual says the compression test does not tell. It does say that idling the temp is fine but 3000 rpms or more is where the problem occurs??? I read something about bubbles and a clear tube. Does anyone know about this?
I did a compression test earlier and got 180# on right side and 135 - 155# on the left side 3 cyl. My money is left side. I can't find any info on the leak down test. Can you clarify?
