jserr68594
Thread starter- Joined
- Jun 5, 2012
- 43
I recently purchased this boat with a '94 4.3LX engine. Prior to my purchase, it had set for two years. Upon first taking boat out (When I first purchased it two weeks ago), it ran fine for the first 20 minutes or so. The engine started to cut out and surge at higher RPMs and stalled once. If I backed the throttle down it would stay running.
After having this issue, I changed the fuel separator, spark plugs, and added dry gas. I then filled the tank. It ran fine the next time I used the boat, but I only used a little over ? tank of gas. The next time I took it out, the engine started surging again. I did nothing other than fill the tank up and the surging went away. Towards the end of this trip though, I noticed a little power loss. Also, the boat would idle very low and want to stall at idle. It is very hard to start at this point as well.
The next time I took the boat out, the engine wasn?t surging (It only seems to surge when there is less than ? tank of fuel). There was however a considerable decrease in Speed, RPM and power. The boat would normally run around 4800 RPM/52 MPH with two people in it. I could barely get 4000 RPM and 40 MPH. It also seemed to use a lot of fuel. I changed the distributor cap & rotor and it ran the same. Battery voltages are good. I also noticed there seems to be steam coming from the engine bay on the port side. I do not know if the flywheel is spraying water from the bilge or if there is a leak in the exhaust.
It seems the boat does not surge with a full tank of fuel; however I am now dealing with this sudden lack of power. I do not know if these symptoms are caused by the same or different issues. The boat only has 268 hours as well.
Any input is appreciated!!
