Mercruiser 4 cylinder 470. 1983
letsbarbq
looking at a boat with a mercruiser 4 cylinder 470. anyone with experience with this type of inboard. many has told me to stay away.
D
DJ
Guest
Re: Mercruiser 4 cylinder 470. 1983
BBQ,<br /><br />There has been a great deal of discussion about this engine here, as of late. Do a search using: "470", "Merc 470".<br /><br />Basically, the engine is 1/2 of a Ford 460 cid. engine. Cast iron head, aluminum block. The head is stock 460 along with the pistons, rods.<br /><br />The engine has a great deal of torque and is light for its hp. class.<br /><br />The major issues with it were:<br /><br />1. Charging system. This can be remedied with an aftermarket charging kit-$500.00. It may already have it.<br /><br />2. Closed cooling system. Normally, this is a good thing, however some suffered from a smallish heat exchanger. This may or may not be an issue with the one you are looking at. If it has gone this far, tendency is it's OK. Also, outdrive impeller maintenance is critical.<br /><br />3. They tended to be a little rough running when cold.<br /><br />This set up can be made into a 185 with a 4-bbl. manifold and carb setup.
letsbarbq
Djohn19<br /><br />happy to see that you are still here and responding. I've been away. <br /><br />I've heard that it has a alum block and steel heads. Which equals a unstable motor. Is there any truth to this? i'll do a search and do some reading ...thanks for the reply.
John Carpenter
People seem to either love or hate these engines. My mechanic won't work on them...but he is a little different himself ;) As noted above they do have some issues and probably need watching a little closer than some others. That said...they have good torque, excellent hp. to weight ratio, and are very fuel efficient. I would not refuse to own one, but would want to buy the boat right.
D
DJ
Guest
BBQ,<br /><br />The disimilar metal issue is really not an issue since the engine has a closed cooling system. No raw water should ever reach the engine.<br /><br />As long as the system is maintained (fresh coolant) it should be fine.
