bmitchell82
Thread starter- Joined
- Apr 25, 2015
- 9
Boat is a 1997, I believe the motor is as well. Power trim works fine going down, going up it intermittently does not work (Just clicks). Ruled out the relay by swapping the wires and the problem persisted. When I am able to get the up to work it is normally by rapidly switching between up and down on the trim switch and then up will start working. It will stay working for anywhere from a minute to a month, and then the problem will return.
I have also ruled out the switch being the problem as it occurs on both the trim switch in the boat and the one on the motor.
There were plenty of corroded wires, but best I can tell, all of them related to the trim operation are in good condition.
I was heavily suspecting it to be the UP solenoid, but upon further inspection and research, I found that this motor only uses one solenoid for the up trim, down trim, and starter. Both the down trim and starter work without issue 100% of the time. Is it possible for the solenoid to cause a problem for just the up trim when it is an all in one solenoid?
This is the style solenoid that it has: http://bpi.ebasicpower.com/pc/ARCSW054/OB-MERSOLREL
If that is not a possibility, what else could cause intermittent issues with the up trim only?
