Mercruiser 454 I Need Help Identifying This Engine
jws123
Well I am back! I bought a speed boat its been a few years since I have owned a boat. The 454 engine in this boat is shot It had water in the oil. I tried to save it but it was bored out to many times and was just all wrong.
I have a spare Merc 454 Mag out of a boat that had a bravo 3 drive that I have had sitting on a shelf for 5 years. I tore it down today It looks like I can save it I did find that it has roller lifters I guess thats good?. My question is I forget how to find out what year this engine is so I can order new rings ect. I no longer have any marine stores they all closed so I have no one to ask ahah. I am basically doing a backyard rebuild and need to freshen it up The serial number Is F088 10237297 Any help would be appreciated.
jws123
I also found 10232427 stamped on the top of the pistons I have no knowledge of this engine if it was ever built ect.
Only way to determine if the motor was rebuilt is to pull it apart and inspect it
Measure the bore diameter, the crank journals, etc
Post your casting numbers. The 454 mag is a rectangular port motor where most of the 454s were oval port
jws123
Here are some pictures yes i know its dirty its getting dunked once its taken apart.
Stock L29. 330 hp
10237297...454.......96-up...4-bolt, Vortec 7400", "L-29" Gen.VI
Oval port
10114156...91-up...oval...OPEN...Gen.V & VI 454, 118cc chamber
jws123
Thanks for the information!! I have one other dumb question that im confused about. This is the engine In the boat its seized and scrap It had a brand spakin new intake on it. Can I re use it? the intake shape looks diffrent compared the the ones posed above they are more of the oval shape but the ones I posed above appear more of a circle?
The intake has to match the heads. As stated prior, your magnum has rectangular ports and needs a rectangular port intake
The motor in the pictures is a mix of Gen 5 oval port heads on a Gen 6 block
Before staying the motor is seized, pull the drive. Because if the drive is seized, the motor won't turn
jws123
The drive is already removed does anyone know a good place to get short blocks? The engine i was going to use after honing the cylinders today they didnt turn out good enough. I dont have any machine shops local anymore and I know jasper ect is crap now.
Scott06
Try michigan motorz they do reman engines not sure if they offer short blocks but they have long blocks
You can't just dingleberry hone cylinders. You need to bore the block, then hone it.
Not sure where you are at, but there should be a good machine shop within an hour or two
