Rranger
- Joined
- May 18, 2009
- 475
My cylinders extended no problem after installing engine and outdrive in a new boat. But they won't retract. The starboard one with both hoses off would not retract when I tried pushing on it. Didn't see the need to check the port one knowing the starboard one is seized. I have a couple of questions, should I remove them and use a press to try to pop them loose and if they pop loose are they good to go assuming the seals are still good.
