Mercruiser 470 3.7 180 Blowby
rozicrc
I have a 180 (basically same motor as a 470) I rebuilt a few years back. The motor was tight with a cold compression of 152 psig on 4 clicks when fresh. I had an episode with the wrong float supplied in the carb that was flooding out the carburetor and intake enough to kill the motor, in addition to a bad coil with 8 hours on it. Long and short of it is I got it running again and it runs like a champ. I did notice after a longer run the breather by the flame arrestor was smoking when the engine was shut down after a prolonged high speed run. When home, I ended up pulling the oil fill cap at idle and idled the boat on muffs. It felt like it had a good amount of puffing, but when I put a piece of paper over the cover it barely fluttered. The fluttering/pressure wave pretty much disappears when I run it up to 1500 rpm and up, but at idle it feels like it is breathing heavy. I am burning no oil and don't know what else could be doing this. Compression on a warm engine is 140 psig on all 4 cylinders.
I suppose it is possible I overlooked this on the rebuild, but does anyone else with a 470 have a similar observation? Thanks in advance for any insight into this.
Ron
stonyloam
the crankcase vents into the valve cover, so any smoke and fumes would come out of that flame arrestor fitting especially after a high speed run. I guess some air movement from all of that mechanical stuff thrashing around in crankcase would cause some air movement at the oil filler, especially at low RPM. You have good numbers and it is running good, so it sounds like it is pretty normal.
