Mercruiser 470 blowing coils
blkzoe
I've got an interesting problem. I've got an '86 Sea Ray Amberjack with twin FWC 170hp 470's. I swapped out the points ignition on each engine and replaced with the Pertronix II 1146a electronic ignition. Yes, I bypassed the resistance wire from the choke. Both engines run like a dream. I can make them idle at 500rpm forever. Torque during holeshot is second to none. I've even kept the cruising temps at about 170 degrees when the Bay temp is as high as 86 degrees; idling temp is at thermostat temp (160). So, what's the problem?
The port engine eats coils for breakfast. It's so bad I carry spares. Starboard? Same coil for God knows how long; no problems. So we have two engines wired exactly the same, yet the port engine destroys the ignition coil on a regular basis. I've examined the circuitry and found no shorts or obvious wiring flaws. Each coil has a 3 ohm internal resister as recommended by Petronix for 4 cylinder engines. BTW, the wiring is really low tech. See link for wiring diagram. (http://forums.iboats.com/filedata/fe...3&d=1400785086)
Here's my only hint at the cause. Right before I pulled the boat for winter I had both engines started and warm. They purred, no issues. I shift the port engine into gear and the engine stutters then dies. No restart. My first response now is to swap out the coil. Swapped coil; instant restart, engine purred.
POSSIBLE CAUSE OF COIL FAILURE(?): When shifting, could the shift interrupt (old style) cause a surge? I've read where surges can cause coil failure. Anybody else have this issue? I'm grinding my molars over this one. Any input would be appreciated.
Bt Doctur
Whem you remove the points system and the resistance wire you MUST use a coil that has a internal resistor
or the full 14 volts will burn up coils.
blkzoe
Agree, am using 3 ohm internal resistance coils (NAPA)
stonyloam
I think the 3 ohm coil is the one with the internal resistor. Stock coil is 1.5 ohm with a 1.5-1.8 resistance wire. The 1146A is designed to work with the 0.3 ohm flamethrower II coil. The Ptronix Ignitor II does change the dwell as rpm increases, could be that at higher rpm it is just drawing too much current for a stock type coil and it is overheating (just a wild guess). I would suggest going with the flamethrower II, and maybe giving Petronix support a call. My Flamethrower II (epoxy) is about 12 years old and always worked fine. Good luck.
HT32BSX115
Coil failure is usually due to excessive current. There is no way a "Surge" could cause a coil to fail unless it was a surge to many times more than 12v.
It's possible that you have a coil that is mis-marked as having an internal "resistor"
bman440440
swap out the pertronix module from one to the other and see if that engine starts blowing coils... if it does you know the module is bad if not you know its the wiring somewhere
stonyloam
A failing water cooled regulator can let the voltage output to go above 16 volts. Might use a good volt Meyer to check in the spring.
JustJason
Did you change out your cap, rotor, plugs and wires yet? If there is anything on the secondary side of the high tension system that is causing excessive resistance to current flow, be it a bad spark plug, defective cap, or a bad plug wire, the ignition coil is going to step up voltage more than it normally does in order to push through that resistance. Doing this causes the coil to draw more current than it's designed to handle. It will do it for a while, but eventually the magic smoke that makes it all work leaks out of it.
blkzoe
I may have solved this riddle. This type of VR is NOT to be used with a maintenance free battery as an "over voltage" event may occur. See CDI's Installation and Troubleshooting guide for part# 194-9502. Some google research indicates as much as 19V may be produced with a maintenance free battery. An excellent way to bar-b-q your coil. I'll have to check and see what's in the battery cradle in the engine compartment.
link: http://www.cdielectronics.com/wp-con...1/194-9502.pdf
Bt Doctur
Another way is to attach a volt gauge to the coil positive to verify the voltage.
blkzoe
Confirmed; maintenance free battery. Now I wonder if I screwed up the VR as well as bar-b-q-ing the coil.
