mercruiser 470 cam seals repair
jabfd
Re: mercruiser 470 cam seals repair
Thanks stony the gasket is still stuck pretty good to the cover I will try black rtv on the pan and on the sides
Also how deep of a groove does there need to be before you need to get speedy sleeves my cam has slight wear but iam not sure it will cause a problem iam going to try to figure out how to put pics up on here thanks again
jabfd
I will clean with emery cloth.
stonyloam
Most guys use spedi sleeves, but I did not when I did mine about 10 years ago. Mine is still holding fine. See how it cleans up. I am sure seal materials have improved over the past 30 years or so, it might be OK. Run your fingernail over the groove area, if you can feel roughness it would probably best to use the sleeves.
jabfd
ok i ran my finger nail and there is a little roughness i will try the emery cloth if there is still roughness then i should definately get the speed sleeves . does napa sale them ?
jabfd
hey guys this is a little off topic but have any of you ever used the wagner dc60 alternator conversion for the 470 i am picking one up on wed . i was thinking since i have the rotor and stator off it would be a good time thanks Jeff i believe its 68 amp
wrestling coach
I am using a conversion kit from Breezeworks. Discussion Forum: 470 Talk. Much cheaper. Includes brackets, hardware, wire harness, alternator and instructions. Nice piece. Low mount on mine.
stonyloam
+1 with the coach. Save a ton of money with the Breezeworks Breezeworks I also went with the low mount, works great! You will no longer need the stator.
jabfd
Oh I forget to mentioned I am buying it from a guy who bought it and never installed and now sold boat so has no need for it for 125 bucks. That's why I was thinking it was a good idea my reg still works I may take it off and sell it a recoup some of the money back thanks
If it comes with the necessary brackets I jump on it for that price. I have a Delco 10si, and made my own brackets. At first I loved the idea of not having to worry about a belt on the engine, but after the replacement voltage regulator went south... it was conversion time. I just keep a spare new belt in the tool box just in case. ;)
jabfd
Yep it comes with the whole kit belt and all. I like the no belt setup and mine still works but every now and then I would see 16 volts then a little while later it would be back to 13 14 volt so it was probably on its way out not sure though . it's only a one wire alt but I suppose I could change but don't think I'll have a problem . Tried some emery cloth on cam and the rear seal has more roughness then the front seal not sure if I need speedy selves but may just do it any way
stonyloam
Yeah if you are getting 16v at times, time for a change. It sounds like the spedi seals are a good idea. Besides with this winter, you have plenty of time.
jabfd
hello stony iam trying to find speedy sleeves i call local napa guys said they dont carry them so iam online and it looks like at the end they have a flange is this right or am i looking at something different is the flange ok to stay there ? stony i know this winter will not let up i plow and iam sick of it !! but I good i made some money so i can spend it on my boat lol thanks again
Capt. Click
Hey, for speedi sleeves try Motion Industries. That's where I get mine. They have a walkin store locally here.(P'cola, Fl.)Sierra sells a seal that is .03 smaller than the original seal. The flange you are referring to is for installation and can be pulled off.
"GET'EM OFF THE BOTTOM"
The flange is there to install the speedi on the cam. After which you remove it. My local auto parts store did not have them in stock but their distributor did so was a day or two wait to arrive.
jabfd
Ok guys I picked up the alternator today great deal I pressed in the new seal 2cam and 1 crank now I know when I put the gaskets on I think it said to put perfect seal . Can I use permatex aviation sealer for all the gasket thanks guys
