Looking at an 83 Mercrusier 470 and need some advice on what to check over on the outdrive. All hoses and boots are in good shape, no noises when prop is turned. Where is the oil checked? And what should I concider if by chance there was water in the oil? Additionally, the motor is said to be fairly new. Has been sitting for several years.. Ive taken some things apart and motor wise looks very clean. Are you able to turn the motor over by hand on the front 3/4" bolt? Any other suggestions? THANKS SO MUCH
