MerCruiser 470 lower unit and a MerCruiser 153 engine
RonWilder
Will these two match up? I am having difficulty seating my foot. I am 2 inches away from being lake worthy
achris
More fish than mountain goat
Apart from the gear ratio in the top box, the drive (both halves) are identical.
Are you having trouble getting the drive all the way into the bell-housing, or the lower onto the upper?
Bt Doctur
you dont list a year but a 8 spline upper will not accept a 13 (12?)spline lower unit
achris
Shift shaft splines, water tube or drive shaft splines.
Bt Doctur
lower unit driveshaft spline to upper gearset spline must match
RonWilder
MerCruiser 153 2.5L and a 470 foot
When I tighten the foot up the last 1/4 inch the engine will not turn over easy. When I back out the foot bolts about a 1/4 inch the engine runs like a top. Any ideas folks?
you should be keeping all related topics in one thread.
RonWilder
This isn't related to matching up splines. This is about a bind on the flywheel coupler
Ayuh,..... Welcome Aboard,..... Ya haven't mentioned 'bout what vintage this ole stuff is,...
But, I'll venture a guess anyways,....
Back with the ole MC-1s, the Chevy based In-line motors, used a shorter input shaft, than All the other motors, 'n drives,.....
'bout an inch difference,.....
I'm guessin' yer stuffin' a drive with the now standard 9" input shaft into a transom assembly that requires the 8" input shaft,....
Or, the gimbel bearin' is massively outa alignment with the motor's drive coupler,.....
