thedockboy
Thread starter- Joined
- Jun 1, 2011
- 14
Mercruiser 470 -4 cylinder 170 HP, serial #5416868 keeps overheating. Replaced hoses, thermostat, water pump/impeller and keeps overheating. Water wasn't flowing so recently removed lower unit to replace waterpump/impeller - old impeller was good but casing on water pump seemed a little melted on the outside as did the sleeve connecting to water inflow pipe. While unit was off connected a hose to the inflow pipe on upper unit and ran the hose without starting engine. Hose circulated water all the way through the unit back out the crack in exhaust bellows. Removed drain plug by exahust manifold and water shot trough as well. After replacing the water pump/impeller etc. and re-instllaing lower unit, started engine with lower unit in large drum of water and water began to flow through systemthought I had it fixed - Shortly afterwards water stopped flowing and engine got hot. I am at a loss as to what it could be - any ideas?
