Mercruiser 470 Rod Bearing
ddrieck
I'm rebuilding a Mercruiser 470
These numbers are showing on rod bearing
Needing to know if these are standard size bearings
CLEV. .112
68704-2
2-8
Pmt133
Typically they are stamped standard (STD) or whatever oversize they are (.010 etc) I would say they are probably standard.
Scott06
CLEV. .112
68704-2
2-8
Would also agree they prob are std but I woild
Measure the crank joirnal
To confirm size. Never know if someone has been in there before
Need to measure the journals, the rod ID and while at it, the bores
ROY WILLIAMS
I'm rebuilding a MerCruiser 470
CLEV. .112
68704-2
2-8
year 1978 MCM470 MERCRUISER. ""WILLIAMS"" 1986-2025. engine 224cu.170hp.4btdc timing 600-700rpm
ENGINE OIL 30W and sn plus 4oz. 5.5QT. ENGINE ALCOHOL COOLANT FREEZE 50% DISTILLED WATER 50%.
ddrieck: rod bearing engine 470 ....
