Mercruiser 470 thermostat compatibility
aarons 470
Hello all,
anyone know if the 470 thermostats are interchangeable? My engine (mcm 470) takes a 76270.
I have a new thermostat 99155 it is the newer type, has the spring. I had bought because I thought my engine had a different manifold assembly. THey appear very similar. Both 160 degree.
Thanks
aarons 470
Mercruiser 470 thermostats compatability
Double post
aarons 470
Hi Terry,
i have different engine package. Mine has the shorter elbow more to the rear. Different exhaust manifold. I’ll try and send picture from merc manual. My engine serial number is 6123990.
it calls out the other thermostat, but wondering if the one you just showed superceeds it or is basically same thing?
aarons 470
Diagram on top, sorry a bit blurry I have to take pictures backwards with cell to get them to load.
aarons 470
I called local shop and asked for thermostat with my engine serial number. They suggested the one you stated Terry, the 76270. So it must have replaced the other.
Thanks again
