mercruiser 470 timing
jmccollum
Ok i am finishing up my rebuild and want to make sure i set the cam and crank right. The crank is set with the #1 piston at top dead center, and the cam is set with the valves on #1 being exhaust just befor close and intake just after open. I know after running the timing should be at 4 degrees before top dead center but figured i can get that adjustment out of the distributor. If any one could tell me if this is right or let me know what i did wrong would be greatly appreiciated.
Bt Doctur
Re: mercruiser 470 timing
there are 2 dots or 2 lines that need to be matched when you install the timing chain.one is on the crank, the other is on the cam
then you bring #1 on its compression stroke ,both valves closed
then you can static time it, then run it to set the timing correctly.
achris
More fish than mountain goat
attachment.php
jmccollum
Ok thank you all very much. Judging by the schematic i have the cam 180 out. Thanks for everyones time.
vincechig1975
I have to chime in and say thanks guys, this is really helpful to me.
Pete104
Are you using a new "chain tensioner"? No reason not too!
achris
I just thought about this... Good joke... Did anybody else get it?
jmccollum
Wasn't a joke look at pick I had the cam pointing away from crank.
achris
Been thinking about it. If out by 180 degrees it would work exactly the same, wouldn't it?
Give the man a prize.... Absolutely correct. If the cam is 180 out, then on one full turn of the crank, the cam would turn 180 degrees (1/2 turn).... and be in the right place....
Well done Mr Terry... :D :D :D
