Just repairing the typical water pump leakage problem on my 1980 470 Mercruiser. The problem I have is what orientation is correct for the two cam shaft seals. When I took the old ones out they were both facing in the same direction (cup side facing out). This makes sense for the outer most seal (coolant side) but doesn't seem right for the inner oil seal. Seems to me the cup on the inside seal should face cup in towards the engine block to stop oil from leaking out into the bleed passage. I'm thinking the seals were replaced before and the oil side seal was installed incorrectly. Can anyone clarify the correct seal orientation for me. Thanks
