Blueghost924
Thread starter- Joined
- Sep 19, 2013
- 250
I'm still working out electrical problems with my 1982 Mercruiser 470 electrical system. I'm looking at my 9 pin wiring harness that goes from the engine connection to the 8 pin rectangular plug inside the center console. Aside from the 10 gauge red wire, there appears to be a 14 gauge red wire in the harness. I'm not sure why it's there, but it does appear to be cut. Any ideas why this smaller 14 gauge red wire would be here? I did a physical count, and all 8 wires that should be there are physically there, and match the electrical diagram for the Mercruiser 470 (batter circuit).
Offhand, with the 9 pin (8 wire) connector plugged in and the battery connected, is there a way to see if the ignition switch is getting juice? I know the wires 5, 6 and 7 are involved with starting and running. I'm currently using jumper wires directly at the engine wiring at pins 5,6 and 7 to an ignition switch to get the engine started, but I need to get the wiring system correct as to be able to start at the center console.
Thanks!
Thanks!
