bassboy416
Thread starter- Joined
- Jul 9, 2013
- 79
I have an 87 mercruiser 5.0 with a chevy 305. I rebuilt the carb this year after de winterizing and ran the boat 3 times with only minor adjustment issues. This weekend I took it out and I noticed at first it would intermittently not get on plane right away at WOT. After fishing at idle for a while, I went to take off and it seemed as if it was totally loaded up and wouldn't get on plane. I wasn't incredibly concerned about this, except on the way to the dock to pick up a passenger it started misfiring and running really poorly driving at about 10 mph at wot and shaking and occasionally backfiring. It would idle perfect, and rev in nuetral perfect. After picking up the passenger it continued to deteriorate. The passenger claimed to know how to adjust the carb, so we messed with the adjustments on the carb noticing very little difference at wide open throttle. It just wasn't making much of a difference. Then, watching the motor while in gear at WOT I noticed three spots up high on the back of the motor spitting out water pretty bad. It didn't look like it was cracked it almost looked as iif there were three factory holes there. I also began to notice a very large stream in the front (under the pulleys) at the very bottom of the motor. At this point the motor would not even try to start. It would only crank without any sputter or sign it was even trying. The boat filled up with a ton of water and the bilge couldn't keep up. I started bailing by hand and barely kept even. What could I possibly be looking at here? the boat has run great for years without any issues, I have no idea if these are related or not. I was assuming fuel or electrical until I noticed the water. now I have no idea. Thank you ahead of time.
