shoestring
- Joined
- Apr 25, 2009
- 107
Re: mercruiser 5.0 mpi hard start when warm
well i have my flowbench proven injectors re-installed, I have checked my fuel pressure, 38 @ idle, 42 w/ vacuum disconnected, drops to 32 when i shut the engine off and holds solid for 10-15 min. plugged in my scanner and didn't get any codes that would support my problem, tps goes from 0% up to 99%, coolant temp matches helm gauge up to 160-could go haywire higher but 160 is all i can get on the muffs. saturday i'm going to play with the iac a little and see if something may be hanging up there. I'm not sure what the ecm should be telling the iac to do at warm start but i think it should be higher than what it is at idle if not @ 100% open during start. when i start hot or cold the engine only goes up to idle, it doesn't run up to 12-1400 and then back down to idle like most mpi cars do @ start, not sure if it is supposed to. the iac is working while it is running, between neutral and gear i can tell the engine is responding to the load, i understand the iac runs full open to full closed everytime the key is turned on, i guess it could start hanging up when it is hot. if i run into a dead end on the iac, i guess i will have to take my tools out on the water and test it out when I am having the problem. I was hoping to solve this before then. is there anything i have missed, i welcome any other sugestions anyone might have. thanks ss
